I understand that the KME is supposed to be built way better than the Lansky. But the "budget" aspect of it seems to not be there at all. Why would someone choose the KME over the Edge Pro? Diamond stones versus the Edge Pro water stones? Clamp versus table?
The main thing for me is, the KME doesn't seem to be in the same class as the Lansky at all.
Brian.
Your'e right, the KME is not in the same class as the Lansky...much higher value and precision for not too much more after you build up all the parts to come close the the achievable edge. I just looked at the KME site, and the new slightly higher price for the KME is with the base, extra coarse stone, and roo strop included. It's a set up that a relative novice sharpener can start getting some pretty refined edges with.
As for the difference between KME and EP, I would say the KME lands right in the perfect spot between the Edge Pro and Wicked Edge. You have a portable, holdable, clamped system, that can deliver rivaling the others. I'm not saying anything bad about any of them because they all have their pro's and con's, both with functionality and price.
Personally I have both the EP and KME (as well as multiple Sharpmaker's). For an average knife without really funky nuances, I grab the KME. Maybe it's just because I'm lazy, and it's easier to just grab out of the box and work an edge while sitting in bed watching tv. Personally, I like the clamped knife, because you don't have to worry about every movement changing that angle. Even a slight angle change (and I mean tiny) between flips from side to side can make the difference between an average (or less) edge, and an amazing one.
But....I still use the EP for a number of knives. One of the EP's advantages is that you can move the blade around to work a blade that is a little different than average. Large knives, some with really odd curves, odd shapes and such...then this is my go-to system. It allows you to apply a little craftsmanship in the process.
And least but not last....the SM. You can really extend the life of a knife if you don't reprofile and remove a bunch of metal any more than you need to. Use the SM to hone that edge/bevel that you already made perfect on a guided system. But this isn't a no brainer with a learning curve either. Because not every knife comes in right at 15/30 or 20/40 degrees. In fact, very few knives I've worked on are right on those angles. So then you have to either find the random angle to hold the knife through the stroke (not easy to do), or just use it as a hone to touch up or add a micro bevel. I use the fine and extra fine rods the most.
Sorry about being long winded. It's just that I went through the early learning curve very frustrated and wanted to achieve amazing results, with the simplicity of a pocket pull-through sharpener. Just not possible. Each system has a learning curve. Each have areas where they really shine. But the super budget big box products will usually give you a super budget end result.
I should add that I have not tried the WE just yet, mostly because of price. But if I had the money, no doubt I'd have one of them also. I am pretty impressed with the set-up and all the downline options. But I'd probably spend myself into oblivion before even getting it mastered.
