- Dec 14, 2004
Just wondering what kind of lube destroys o -rings. I would think synthtic silicone lube would be safe. thanks for the help.
For Hi Vacuum and Ultra Hi Vac, most seals/orings are metal to metal gaskets made of materials like copper compressed between "knife edge" sealing surfaces. Most conventional orings are either Buna, silcone, or Viton and use little or no lubricants. Specific lubricants used in HV and UHV have low vapor pressures to reduce outgassing. Lubricants like Castrol's Braycote 600 run about $600 for a 6 oz. tube though. Crytox, Torr-lube, and others are a bit cheaper but not really needed for normal everyday uses.TLM said:The safest silicone lubricants are those used in vacum applications, they have no volatiles, not cheap though. Most serious silicone greases don't have any petrochemical volatiles because that kind of negates the whole point of using silicone.
TLM
