Don't even waste your time or money, tried it and it dosn't work worth a damn. The frame work, bearings etc. were not made for this. The speeds necessary are so high and the tension so tight that it will tear up a cheap saw in no time. Equipment for this includes full face protection and a football helmet, when a blade snaps and believe me it will, it can still drive you to your knees. All I could ever do was straight cuts, no curves. Listen to Rob, slow that puppy down, you'll be surprised what you can cut and how long your blades will last. A band saw blade needs proper breaking in to operate well. Don't just cram a piece of material through the saw, take your time with a new blade, especially cutting steel. You can easily knock off a bunch of teeth by just shoving it through as hard as you can.
Using proper feed rates and tooling speeds will help you do a beter job and help make your tooling last a lot longer.
Ted
MMHW
