Will the cracks lose too much heat?
My neighbor gave me a forge body he made out of fire brick that he mortared together with fire place mortar. For one reason or another some cracks developed in the mortar. I have all the parts to build a burner for it but was wondering if I would lose so much heat through the cracks it would be a waste of time?
Thanks for any help or advice you can give me!!
Can you just plaster over the cracks with more fireplace cement? If you have a big enough fire you can overcome as many cracks as there are but I think you want it as efficient as possible.
I got some pre-mixed fireclay, as well as some IFB and a castable refractory called "lightweight", made by AP Green, from a supplier in Mobile, AL. I cast a solid-body forge out of the stuff, and used the fireclay and a few of the IFB to finish it. It's powered by 2 Reil EZ burners with Tweco welding tips as gas jets. When i saw that it was developing a few hairline cracks, I wrapped the whole thing in 2" Kaowool, and wrapped the whole thing with a piece of rolled 1/16" steel sheet(like a metal sheath covering the outside of the forge). I simply MIG welded the seam on the steel where it overlapped. Painted the thing flat black, and put flames on it in Grabber Green and Hemi Orange (had the paint and couldn't resist!). I mention this because if the fire place mortar is anything like the fire clay I have, it doesn't seem to work real well for plastering. It works well for mortaring bricks to each other, or to refractory though. The cracks in the mortar will definitely lose heat. You may need to use a different kind of fire brick - IFB for instance, and mortar the body up with fireclay since it probably has a higher temperature rating than commercial fireplace mortar.
Thanks Bennett!
Hey, I never did get your email.
You didn't send it to L6steel@aol.com did ya?
I left aol better than a year ago. I'm with earthlink now. I don't know which stinks worse, lol. CooperKnives@earthlink.net
I think I'll just carefully take this forge apart and save the fire brick for other things. One thing is the bottom of a forge made with the ceramic blanket stuff. I think most folks do that to help keep from damaging the lining don't they?
I can cut them in half thickness wise on my table saw so they won't take up too much room.
