- Sep 29, 2015
I finished the HT for a practice kiridashi (26c3 steel) and I seem to have gotten an auto hamon due to the thickness of my stock ( 1/4”). My HT was heat to 1475, hold for 10min after the temp equalizes, quench in parks 50, then temper 2x for 1hr at 350°. My evenheat seems to read a tiny bit higher than the actual temp so I compensate by 15°.
I did apply clay to the blade to prevent some oxidization, and then left a ~1/16” thick layer roughly 3/4” away from the top of the bevel. But I doubt this had much of an effect on the hamon, the stock I used was admittedly a bit over kill, but this is a test blade and I have more 1/4” stock than 1/8”.
Will this significantly effect the performance of my edge as I finish up the blade and put it to use? Or is these enough room between the edge and the hamon that for testing purposes this is fine?
Thanks,
Kevin
Thanks,
Kevin
