- Jun 3, 2009
for myself at least sharpening recurves sucks, let alone trying to change the profile, in my case i have a ZT 0300, and i have tried clamps, crock sticks, freehand, and a HF belt sander which didnt work out too well (thankfully Kershaw has an incredible warranty, and just sometimes they will ever cover stupid) anyways threw researching the internet everyone of the reasonably priced sharpener had some type of major compromise when working with a recurve. so my idea is if i trace the exact shape of the blade. then take that outline and use it to crate template out of teflon or some type low-friction type plastic. so back to the idea, now i would have two exact blades. taking the orginal steel blade clamp it down to a work bench type area, now take your teflon replica and keeping prefectly in line raise the teflon blade and raise it to there is a 15 degree angle between the point of one tip and the tip of the other steel blade. now because you have two of the exact same pieces of material instead of having to work your way around the curves, you could use a steel rod that would be resting on the teflon blade that is connected to a diamond sharpening rod that will be moved back and forth at a 90 degree to both blades. because you would be follow the same angles on both blades and the same time you wouldnt have to ajust for the belly and tip. wish i would have drawn up my idea, explain this is a little harder than i thought. i know there would be some very little compromises like the teflon not being angled at the ame degree as the bevelm but i think that could be compensated for. i anyone has any ideas, plans please feel free to speak up. thanks landon
