Will this motor and VFD work together?
Hello all,
I'm getting an origin belt grinder chassis and looking to save a couple hundred purchasing the VFD and motor separately. Just wondering if the motor and VFD I linked below will work well together? The KBAC has some options you can purchase with it. I dont think I need any of them but would like to some advice from knowledgeable people before I drop my hard earned $$. ha. I am having a 220 outlet installed for this.
https://www.automationdirect.com/ad..._(0.33_-_3hp)_te,_footed_rigid/mtrp-002-3bd36
http://www.electricmotorwholesale.com/9667-KBAC-27D-GFCI/
With the 1750 you'll have more torque, and with the large drive wheels you'll have all the speed you need.
You can run 3600 but you'll want a smaller 4 inch drive wheel and a lot of guys here generally won't recommend 3600 motors for a belt grinder.
You can run 3600 but you'll want a smaller 4 inch drive wheel and most guys where generally won't recommend 3600 motors for a belt grinder.
Great thanks! I was looking at drive wheels at origin they only have one 5/8" shaft, it says the dimensions are 8.6875 x 5.4375 x 1.75 in. Is that what you used?
Also make sure that if you wire it for 110 to not run the VFD on a GFCI outlet, it'll trip the outlet and won't function correctly.
I was planning on getting contact wheels from ameribrade they seem to have great deals on them.
Thanks again for the info!
No problem, I have a 10 inch wheel that is out of balance and kevin is going to replace it. They're good people, they've worked with me to correct any problems or questions I had.
