- Oct 1, 2009
I have this motor from work, I’ve been think about building a grinder for a long time, if this one would work I think I’ll go for it.
I’m not too worried about the power for now, I don’t plan on hogging off material too much, I forge the basic shape and use a bench grinder to clean up what I messed up so this will be for mostly beveling and cleaning things up.Looks like an ok Motor. I personally like to start with a 1740 rpm motor. Thy usually handle around double the HZ easily. My issue with a 3450 motor is if you turn it down with a VFD to 1750 you have lost a good bit of your HP. So starting at 1740 works good for me as I can go to 120hz or drop to around 30 or HZ with out any issue. The faster motors will work to but I don’t think thy are as stable when over driving them up to double the HZ as I don’t think thy are rated for that kind of speed. I have a VFD rated motor that’s rated for crazy speeds but it’s unique. But like I was saying that motor will work and get you going.
I’m positive I don’t have the skills either haha I’m sure I’ll mess up more than I don’t but that’s just part of learningAgreed, it will work. Not what I consider ideal, but others will disagree.
Lots of folks like a screaming fast motor, and I can't fault their reasoning, but I just don't have the skills to grind that fast!
I have more than enough power at my house for it I’m not too worried and I’m going to be having a shop built soon and a whole new line of 200 amps ran to it so I should be good there and I’ll just have a VFD built at work with old parts so I won’t have much cost there.It will work .. with a VFD ... on 240VAC.
As said by the others, I prefer a 1750RPM motor. But, free is free.
You can always change it out later for a 1.5 or 2HP 1750RPM if one comes along.
I have access to a machine shop and a passable amount of knowledge to work everything there I’m just planning on making all the wheels my self so shaft size won’t be too big of an issue. But I will take your recommendation for the wheel size into consideration. I really have a lot more research to do on this it’s really only ever been a passing thought before yesterday.Keep in mind that the shaft diameter on a 145 framed motor is 7/8", so make sure you order your drive wheel accordingly. IIRC, the face mounting dimensions should be the same, so that shouldn't be an issue. Given that it's already at 3450 RPM, I'd recommend starting with a 4" diameter drive wheel. That will still give you more than enough top end speed (especially if you double your frequency), but the low end will be a bit more manageable as well.
Maybe I’ll mess around with that too. I might make a bunch of wheels to try out and see what works best.If it was me I would try a 5” wheel at 60hz gives you around 4500sfpm where I consider the sweet spot for the type of grinding/roughing we do. Yes you can grind faster and I use to be one of them. My grinder use to top out at about 10,000sfpm. But power in the low end sucked. Anymore I seam to be in the 2-3k range for what I do. Your highest load is going to be roughing so design your grinder to be running at 60hz at that sfpm abd you will have all the power you need. I WOULD not over drive a 3450rpm motor.
I plan on just having a VFD built at work, I figured there is no point in having a 3 phase motor without one. I will definitely look into the ratios for smaller wheels too.Yes, use a vfd.
If your worried about speed being too high or losing torque at lower rpm.s use a smaller wheel.
Not too much hp?That second motor should work well.
Haha sorry it was meant to be a joke, I work at a large motor repair/ new manufacture shop as a DC Winder, it’s really really rare we get anything lower than 15 hp and honestly anything under 100 hp we usually just buy a replacement from the original manufacturer. It was kinda a miracle I found that 2 hp motor.Oops! I glanced and saw 1.5HP. Yes, that's a big big.
You know , that s not bad idea at all ...............I'd kinda like to see a 3000hp belt grinder....
That's exactly the case with a 3450 rpm motor. I've been using a 3450 rpm motor for several yrs and never notice any lack of power at lower RPMs because as JT says with the finer grits used at lower RPMs full power isn't required. I use a 4" drive wheel with motor max'd around around 3800 rpm for a max belt speed of 4,000 SFPM. I doubt seriously anybody would ever notice the difference between a 1750 and 3450 rpm motor while using.But generally I find as I slow the grinder down I’m going to finer and finer grits which require less and less pressure so it works out good.
