William Henry Mattlock
"Abstract
A folding knife having a handle and a blade attached to the handle, the blade being connected for movement between a retracted position and an extended position with respect to the handle, and the blade a first locking profile, such as a notch. A locking member is provided having a second locking member, such as a projection, the projection being configured to be engageable with the notch when the blade is in the extended position. A pivotal connector is connected to the handle and to the locking member for allowing the locking member to pivot with respect to the handle. The locking member is movable between a locking position, wherein the second locking profile is in locking engagement with the first locking profile for locking the blade in the extended position, and an unlocking position, wherein the blade is movable with respect to the handle. A spring is connected to the handle and to the locking member, between the second locking profile and the pivotal connector, for pulling the projection into locking engagement with the notch when the blade is in the extended position. "
anyone want to explain this to me:
"1. A folding knife, comprising:
an elongated handle having a forward portion and a forward end;
a blade connected to said forward portion of said handle, said blade having a pivotal blade connector and being connected for pivotal movement between a retracted position and an extended position; said blade having a first locking profile and a retention profile;
a locking member having a second locking profile, said second locking profile being configured to be in locking engagement with said first locking profile when said blade is in said extended position and in engagement with said retention profile of said blade when said blade is in said retracted position for selectively retaining said blade in said retracted position;
a pivotal connector connected to said handle and to said locking member for allowing said locking member to pivot with respect to said handle; said locking member being movable between a locking position, wherein said second locking profile is in locking engagement with said first locking profile for locking said blade in said extended position, and an unlocking position, wherein said blade is movable with respect to said handle; and
a spring connected to said handle, between said forward end of said handle and said pivotal blade connector, and to said locking member, between said second locking profile and said pivotal connector, for pulling said locking member towards said locking position.
2. A folding knife, comprising:
a locking member having a second locking profile, said second locking profile being configured to be in locking engagement with said first locking profile when said blade is in said extended position;
a spring connected to said handle and to said locking member, between said pivotal connector and said forward end of said handle, for biasing said locking member towards said locking position.
3. A folding knife, comprising:
an elongated handle having a forward portion and a forward end adjacent said forward portion;
a blade having a pivotal blade connector connected to said forward portion of said handle for allowing said blade to pivot between a retracted position and an extended position;
a locking member having a pivotal connector connected to said handle and to said locking member for allowing said locking member to pivot with respect to said handle;
locking means for locking said locking member with said blade when said blade is in said extended position for retaining said blade in said extended position; and
a spring connected to said handle between said pivotal blade connector and said forward end and to said locking member for biasing said locking member towards said extended position.
4. The folding knife as defined in claim 3, wherein said locking means includes a first locking profile defined on said blade and a second locking profile defined on said locking member, and wherein said second locking profile is in locking engagement with said first locking profile when said blade is in said extended position.
5. The folding knife as defined in claim 3, wherein:
said locking means includes a first locking profile defined on said blade and a second locking profile defined on said locking member;
said second locking profile is in locking engagement with said first locking profile when said blade is in said extended position; and
said spring is connected to said locking member between said pivotal connector and said second locking profile.
6. A folding knife, comprising:
an elongated handle;
a blade connected to said handle, said blade being connected for movement between a retracted position and an extended position; said blade having a first locking profile;
a spring connected to said locking member, between said second locking profile and said pivotal connector, and to said handle for biasing said locking member towards said locking position.
7. The folding knife as defined in claim 6, wherein said blade defines a tang portion and said first locking profile being adjacent said tang.
8. The folding knife as defined in claim 6, wherein said blade is pivotally connected to said handle by a pivotal blade connector and wherein said blade pivots between said extended and retracted positions.
9. The folding knife as defined in claim 6, wherein said handle has a forward end and a rearward end, and further comprising a pivotal blade connector connected to said handle and to said blade for allowing said blade to pivot between said extended and retracted positions; and wherein said spring is connected to said handle between said forward end and said pivotal blade connector.
10. The folding knife as defined in claim 6, wherein said first locking profile is a notch defined by said blade.
11. The folding knife as defined in claim 6, wherein said first locking profile is a projection on said blade.
12. The folding knife as defined in claim 6, wherein said first locking profile is an aperture defined by said blade.
13. The folding knife as defined in claim 6, wherein said second locking profile is a notch defined in said locking member.
14. The folding knife as defined in claim 6, wherein said second locking profile is a projection on said locking member.
15. The folding knife as defined in claim 6, wherein said second locking profile is an aperture defined by said locking member.
16. The folding knife as defined in claim 6, wherein said spring is a wire spring.
17. The folding knife as defined in claim 6, wherein said spring is a coil spring.
18. The folding knife as defined in claim 6, wherein said spring is a tension spring.
19. The folding knife as defined in claim 6, wherein said blade defines:
a tang portion;
said first locking profile adjacent said tang portion;
a retention profile for engagement by said locking member for selectively retaining said blade in said retracted position; and
a guide profile extending between said first locking profile and said retention profile, upon which said locking member bears as said blade moves between said retracted and extended positions.
20. The folding knife as defined in claim 6, further comprising at least one projection on said locking member for engagement by the user to move said locking member between said locking position and said unlocking position.
21. A method of constructing a folding knife, comprising:
providing an elongated handle;
providing a blade having a first locking profile;
connecting said blade to said handle for movement between a retracted position and an extended position;
providing a locking member having a pivotal connector, said locking member having a second locking profile configured to be in locking engagement with said first locking profile when said blade is in said extended position;
connecting said pivotal connector to said handle for allowing said locking member to pivot with respect to said handle between a locking position, wherein said second locking profile is in locking engagement with said first locking profile for locking said blade in said extended position, and an unlocking position, wherein said blade is movable with respect to said handle;
providing a spring; and
connecting said spring to said handle and to said locking member, between said second locking profile and said pivotal connector, for biasing said locking member towards said locking position.
22. The method as defined in claim 21, further comprising providing a pivotal blade connector connected to said blade and connecting said pivotal blade connector to said handle such that said blade pivots between said retracted and said extended positions.
23. The method as defined in claim 21, further comprising providing a pivotal blade connector connected to said blade and connecting said pivotal blade connector to said handle such that said blade pivots between said retracted position and said extended position, and wherein said spring is connected to said handle between one end of the handle and said pivotal blade connector. "
