William Henry Spire
kamagong
Here's the story. I graduated from school this past Sunday. Since I will soon be joining the ranks of the gainfully employed I decided that I need a gent's knife. As much as I like my Military, it just doesn't go with a suit and tie. A few well placed hints, and I had the WH Spire on its way to me. It arrived yesterday. Since I haven't spent that much time with it, the following comments reflect my initial impressions more than anything.
The Spire is a small lockback that weighs in at 2.4 ounces. It sports a 2.375" wharncliffe blade in VG10. My knife has green jigged bone scales. I had hoped to get one in the red bone, but everyplace my girl visited was sold out of the red bone model. No biggie. The knife is gorgeous nonetheless. Fit and finish is excellent, and the combination of bone and brushed steel makes for a visually stunning knife. The workmanship on the Spire is excellent. The knife locks up solidly, with no bladeplay whatsoever. It also opens and closes very smoothly.
However, the knife is far from perfect. It has a single thumbstud that is reversible. The clip is also reversible. These two are nice touches that make the knife amidextrous. However, I question the usefulness of the thumbstud on a knife this small. I have medium sized hands (4" X 7.5") and I found it very difficult to open the Spire one handed. In fact, it is so difficult to open with one hand that I found it faster to just use two hands. The pocket clip was also problematic. It is too tight. There is no clearance between the clip and the scales, and I doubt that I could clip it onto a dress shirt, much less onto a pair of slacks. It is also very stiff. I don't think I can bend the clip without damaging it. I'm going to have it take it off before I try to fix it.
Overall though I rate the Spire very highly. It's a high quality piece and one that I am proud to own. I think my problems with it are due to my unfamiliarity with small knives more than anything.
In that case, can you loosen it a bit to get enough wiggle room to use the clip? Maybe a small o-ring or some other type of spacer under the clip if the screw is long enough to accomodate it.
I think so. I need to find the appropriate size Allen wrench first. Then I'll take the clip off and bend it gently.
That reminds me, what color loctite should I use when I remount the clip?
I wouldn't suggest bending the clip. You could go to far. It should get looser with use.
Kamagong,
I took the clip off mine, way too tight. I found the screw was a bit small.
The only thing is clip was recessed & when removed leaves 2 sharp prongs that dug in my hand. What I did was file these down & squared it off & put in William henry pocket sheath. As pearl model was a touch slippery insheath I moulded the sheath for a snug fit works greaat now.
Mitch
Good to know all of this.
I jumped onto a Spyerco Mouse (this one was NIB, but it's out of production), which is the same size but a lot taller and beefier.
But if this gets in the way too much, my original choice was a that WH in MOP.
I've had no trouble bending back a couple of pocket clips on my CS Voyager and Spyderco, but I don't want you breakin anything. Trick is to bend it a little as you go along, just a degree or two. You've got a few joints in that clip to work with, so you might want to give it a try.
I can't STAND clipless knives, so I wouldn't take it off for any reason.
_z
