J
Jim Beam
Ok so i moved the wheels back on my platen attachment so that i could get to the true flat and when i did that i had to move the whole attachment arm forward to get more belt tension (because moving the wheels back created slack and i was already at the top of the tension adjuster) when i went to set the whole thing back up the way i had it originally, i could not get the belt to track steadily, it would move around even with the tension back to the closest setting... so my question is: what is throwing off my belt alignment? is it the wheels of the platen not being the same distance in front of the platen, is it the arm being in the wrong place, does the tension wheel have to be high in its arch to get the belt to track right or is it just a question of tension???
Also, i was wondering if there is any way to keep the belt from running from right to left as i start it up, with a 36 grit belt, it is eating a huge groove in my side door at the bottom. Thanks
j
j
