So if you were looking down the blade from the top it should have a lift that would look like this? (Some people that are more knowledgeable than I say the edge should be curved a bit and the back is not perfectly flat but curves up slightly which makes sense for hewing ( and lifting the chips out ) otherwise the corners of the blade will dig in if the wood is wider than the blade.
The newer bench axes have straight edges with no uplift , which no doubt is fine for working a wood piece narrower than the blade is wide.
Gotcha. So it's strictly a big carver likeWhen talking about original American pattern broad hatchets like the one shown it is, for the most part, flat toe to heel and also flat edge to poll, because it is not designed to hew logs. Original American pattern broad axes are , for the most part, curved toe to heel and also curved edge to poll, because it is designed to hew logs.
Plumb offered 7 sizes of Broad Hatchets (Bench Axes)Gotcha. So it's strictly a big carver likeHickory n steel said? How big the cutting edge on this thing? (I wish I could read that picture) Might just be the picture makes it seem bigger than it is?
I'm curious cause it sounds like something I could put to use right now on a project.
Trying to figure out what you mean. That does seem like the only way to keep the edges from biting in though
