- Jan 2, 2015
Today I did heat treated my MDB model which is made from CPM 154 Stainless Steel. We took some pretty cool pictures showing the process so I thought I would share. Thanks for looking!
This is after I hand profiled the blades. After shaping I apply blue layout dye on the blades to mark where my holes and jimping will be. I did this to a total of 9 blades for this run.
Next I apply the file work. I do each notch by hand with a jewelers file. I expect a major handcramp! Heat treat next!
1940 Degrees. Don't pick on my tongs!!!
The blades are plate quenched under pressuring using a drill press. They are cool enough to hold in a bare hand in about 90 seconds. The blade is sealed in a foil packet to ensure it does not come into contact with oxygen at such a high temperature.
The blade after the high temperature stainless foil packet is removed. Next the blades will go into a subzero bath at -100 degrees F overnight. This extra process adds improved edge retention.
I will add more WIP pics as I go. Please feel free to ask me about the process as I go if you have any questions! Thanks for looking!
