- Nov 26, 2010
I just don't know when I'm beat is the simple answer. Anyway, i have birth year sodbuster jr knives for me and the kids (looking for the wife as well) and one or two of them have been modded by professionals, so sitting around in a flea market i find a Case CV sodbuster jr for little cash and that part of my brain that lilies hearing me swear (later when things are going wrong) pipes up and says "hey, you know what..."
And so I have been playing around with it, first I cleaned of some rust with sandpaper and put a good edge on it (by accident mostly, because it's better then the ones I get when i try it on purpose.) I have since learned that is probably best done AFTER you have finished fooling with it, but i really wasn't sure how far I'd go or how long the project would run.
So then I started sanding the scales into a rounded shape, for more comfort,
then putting a pattern to it (which looks dreadful) for the sake of "learning"
"You know, I bet it's not that hard to take apart"
ran into some problems with that
but eventually figured it out
I was talking with a friend I met for the first time the other day after talking with him online for over a year, and he'd done the same thing, whcih may have been what put it back into my head. Or it's because this week it turns out a few different passarounds I'm in came along at the same time and I've been trying to wipe the "unfinished projects" off my desk. I went and found the sodbuster in it's little forlorn home waiting.
Decided to cover the blade up first (lesson learned), and took some of this age debris of the spring and liners with a mid grit sand paper
cut out some rough scales in walnut
Decided to glue (with locktight) the liners on to the scales and made some holes (1/8" stock is the smallest diameter i have so i figured why not just drill through the liner to
I found out why when I realized the middle (rocker?) pin had to go through the spring which I couldn't drill, so I sanded on of the 1/8" pins down. I also discovered that you have to put the tension in the spring before it'll go together, makes sense now I think about it,
This is when I re-learned the "cover the blade" lesson from earlier. Decided to sand the scales down (I've done some fixed blade handles so this was the part I felt comfortable with the most)
Found out one of the liners had come away from the wood in the process, re-glued and clamped in the vice
Decided "what the hell?"
I also had a very poor pocket knife laying around because I though I could harvest things from it if I ever needed, and so i did. problem is poor pocket knives have poor pocket clips so I sanded a curve into the base and started to round it to fit the scales
Ended up breaking it on both sides to get it to move but they are hairline cracks (picture took ages to get) and I think it'll still work
Looks okay.
Treated scales with linseed oil - this is me taking a break while I think, don't think it should be done at this point or anything)
Managed to get the tension on without causing anymore serious harm to myself
Lined it out and found the tension curved the butt pin, so getting it all together was a bit of a job
very surprised to find myself this far along (even if it did take me two weeks and a few scrapes) without too much (subjective term) trouble, I then found out what I'd done wrong... no gluing folding knife pins, is there? So i scanned the BF world and found some info on "penning" pins, if I remember right, and thought I could make a pin out of a screw remover that doesn't work. i did that, then found out the other side of the pin would just go straight thought he wood block I used to race it (could have figured that out first if my head was even as full as the wood block itself. So I tried a few different things
and frankly have come out empty...you can't tell but i am simultaneously curving knives, axes, pins not to mention myself and a few other things rather violently in some of these pictures, and yet it's still fun
so what I have is a fairly well modified, working case sodbuster jr CV, with pins that aren't secured in any way...sitting back int he house I think I've come up with something (why go by a set of pins and a metal bar when you can risk injury again by "making do" eh? but for now, this is where I'm at....and thanks for sticking with it if you made it this far, it's late, I've been beaten, again, and I am one to ramble under those conditions
Also i think i may have trimmed the pins to far to "penn?" them well, looking at other pictures on the WWW. but, I'll cruse that bridge when it hits me in the face, or something like that.
thanks for looking
Looks okay.
thanks for looking
