- Feb 24, 2014
Who haven't yet, please check our discussion on wire edge at the BESS forum
http://www.bessex.com/forum/showthread.php?tid=372
Thank You !It's a bad idea to simply draw the edge through a wood block, rubber or cork to “rip off” the wire edge.
Hi,Who haven't yet, please check our discussion on wire edge at the BESS forum
Hi,
How does this new(?) discovery affect your previously published reports?
Hi,I'd say no how. For mainstream knives the sharpness test itself can tell us whether the edge is burr free. In all those previous studies we looked at comparative sharpness of the edges deburred the same way, not the absolute.
What do you think?
Another thought re Murray Carter - is possible he uses his wood drag more to verify lack of burr rather than to actually deburr. Myself, I've had good luck with dragging through wood for deburring but only if it is done repeatedly, interspersed with a number of passes on an abrasive - not so much with one or two passes at the finish. This isn't my usual, but has worked reliably when I've used it.
FWIW I don't believe this wire edge is terribly common, at least not to the extent it is noticeable with most sharpenings. I suspect far more common to trailing edge sharpening on harder surfaces.
That's true, I should have said "common to edge-trailing honing".
For deburring we use powered honing in our workshop, it is edge-trailing - and this is the study focus.
CasePeanut - leather removes the base burr, though not as well as the flint/rock-hard felt; a Korean sharpener wrote to me that he uses suede in the final step of higher-angle deburring for the wire edge prevention, and the suede works better for that than the plain leather. I am yet to try the suede myself.
LipRipper - I have not experimented on edge-leading deburring, and cannot compare it to edge-trailing.
But as Sergeua has noted, for the ultimate sharpness edge-trailing honing is the only option. If you goal is not a true razor sharp or sharper than razor edge, you can deburr edge-leading.
