Wire wrapped handles.
Its more of a sword thing, but what is your opinion on wire wrapped handles for small to medium sized blades, and does anyone make them? Custom or otherwise.
:thumbdn::thumbdn:
They can be ok when done properly (not easy) but they seem best suited for gloved usage. A wire-wrapped handle held by a doe-skin glove grips like it was doused in superglue! BUT it will tend to be irritating to bare hands.
The only maker I've seen design with wire-wrapped handles was/is Gil Hibben (dunno if any of his more recent designs use it).
I actually had a couple of his knives with this feature, and my experience was that it was never really tight on the handle (always loose and moving about), it was uncomfortable to hold, and I got the impression that if I actually used them the oils and acids from my hands would ruin it in no time.
So... I wouldn't bother as a user. But it did look nice, if you want a wall-hanger.
As I previously mentioned it tends to irritate bare hands but sticks to gloved ones like glue.
To prevent wire shifting a properly made wire grip should have channels or grooves cut into the handle core to hold the wire in position.
It's only rusty if you use carbon steel wire. Brass and stainless do a very nice job--but yes, corrosion is indeed a factor. Another reason to use it with gloves. ;)
I have several custom daggers in medieval style made by Don Horne in Oklahoma City. One has steel wire wrap and the other has Brass wrap. They are made properly and are quite comfortable in use and not heavy nor ill-balanced.
The wire wrap can actually help the balance out if you are trying to get more weight in the blade, and make the knife more neutral, as in a dagger for fighting, or a well balanced sword.
I think Tom Maringer won't make a knife unless it has a wire wrapped handle. I'm exaggerating but a lot of his blades have them. He has a special rig to keep tension on the wire as he twists it up.
I do other wrapping besides wire, but it is a favorite. One problem with the technique in general is that it can be badly done. That Hibben piece mentioned above was apparently never stabilized, and the book by Hrisoulas explaining how to do it got the anchoring and furnishings process all wrong. (Apologies to Gil and Jim here, but I gotta tell it like it is. But when done RIGHT it is superlative in every way.
I have many wire wrapped pieces in service, and have never heard one single complaint about their being uncomfortable on bare hands. (my blade list is here: http://www.shirepost.com/BladeList.html in case anybody feels like actually counting up how many there are, I've never done it)
Doing it right means that:
1. The right material and wire diameter is chosen. Most people use wire that is too thin or a bad material, like brass. I like stainless steel or titanium... and a wire diameter right around 0.030".
2. The pitch of the two-strand twist is appropriate. Most people don't twist tight enough. I like a pitch of between 12 and 14 twists per inch... so that the wires cross each other at close to a 45 degree angle.
3. The wire has to be wrapped TIGHTLY and with constant tension onto the handle core. Most people don't spend the time to do this step right and the tension is either too loose or too varied from place to place. I use a special lathe that holds the handle and turns it slowly, while an assistant with a spring loaded scale puts a constant tension of between twelve and eighteen pounds on the line (depending on the handle core material and the size of the piece) as I feed it onto the handle, using a foot control to gauge the speed of the lathe.
4. The handle core should have some resilience. Micarta is (for example) NOT well suited to wire wrapping as it is too stiff... the wire cannot sink into it and grip into position. I use a tough hardwood material like Ash, Hickory, or Laminated Bamboo as the core material.
5. The wire has to be anchored correctly, at both ends of the handle. My technique always involves metal collars at each end that covers the anchor points, but the anchor is NOT dependant on the collars, they merely conceal the anchor points from showing. By taking down the handle the anchors can always be inspected. The collars and the wire are wrapped around the same handle core and meet at the edges with the collar cut to the spiral of the wire wrap. Putting the collar over the top of the wire as most people do leaves an unsightly step that interferes with the grip.
6. The wire has got to be stabilized after wrapping. No matter what the handle core is, if the wire is not stabilized and the handle shrinks it can become loose. Stablization is done by immersing the finished handle core with the wire wrapping in polyurethane, laquer, or a thin epoxy such that the stabilizing material seeps under the wire, sealing the wood and locking the wire in place. I use a rotisserie for drying to keep the sealant from dripping.
Leaving out any of the above steps can make a hash of the whole thing, but if all those features are in place it makes a great handle. Please don't judge the technique by a poor example of it. I'll have some pieces on my table at BLADE in May. There are many more photos of this particular piece, including more details about the wire anchoring, on this earlier thread: http://www.bladeforums.com/forums/showthread.php?t=613005
I have several pieces with wire-wrapped handles and they are extremely comfortable.....not abrasive in the least and a VERY secure grip.
When done correctly, as Tom stated, they will last a lifetime under virtually any conditions and are good looking to boot, IMHO.
Here are a couple examples by Tom and John Salley....
The wire-wrap on my Maringer Vorpal Haiku pictured here was given a fine bead-blast at my request to give the piece a tutone effect and it did give it a bit more grip.
If you can find a maker that can do it right, the likes that Tom Maringer, John Salley, Scott Shoemaker, etc., can, it makes for a very pleasing haft for both the eye and hand.
I forgot to mention--take a look at pictures of military saber patterns and you can get a good idea of what a well done wire-over-leather wrap looks like. The wire sits very deep and feels quite smooth on the hand.
Wow! Obviously I had no idea. I believe the pieces I had were meant to be looked at, not used, hence their wire-wrapped handle failings...
All those posted look amazing! :thumbup:
I think it's rather sad that there have been some poorly done wire wrapped knives, mostly cheap imports, that have tended to discourage people from trying it. It can be an extremely strong and useful grip when done well. Here's a pic of a recent pair of subhilts with all the furniture AND the wire done in titanium. Big strong knives and they came out featherweight.
