Wirebreaker Notch & RC5 Question
Hi everybody!!
So I was going over my RC5 the other night (after playing with it again for 100th time--I know, I know..I'm gonna keep it up 'til I go blind) but I thought:
"This is a SERE knife, right? The HEST has one, why doesn't the RC5 have a wirebreaker notch?"
Some larger knives have a notch in the spine for breaking wire, some in other places. So I have some issues:
Possible RC5 addition on future knives?
Will milling a wirebreaker in the spine of the knife compromise the integrity vis-a-vis batoning?
A wirebreaker--professionally done or not--put into an RC5 will void the warranty, won't it?
Anyhow...basically what I'm saying is: Now I know if Jeff & Mike thought it needed one they'd have added it previously--but sometimes I'm guilty of not leaving well enough alone. I want to add a wirebreaker to my RC5, but don't want to hurt it in terms of warranty or blade integrity.
Thanks in advance!
I'm sure they'll chime in at some point. If you break alot of wire, I'd carry a small bolt cutter. If I hadda add one to the rc5, I'd think of cutting one into the pommel. Lots of room there, and not much worry about stress points.
Edit: they've said stupidity is covered in the warrenty, but have asked thier direct advice when doing mods like this.
I agree with Diz. I always thought a wirebreaker on the pommel would be the way to go. If I planned on cutting alot of wire, I'd carry a multi-tool.
Multi-tools are fine for cutting a lot of speaker wire or low voltage wire. I wouldn't want to cut my way through hurricane fencing or anything similar with one unless really pressed...better to have a dedicated set of side cutters or diagonal pliers for heavy gauge wires like that.
Whats hurricane fencing? I ask because I've live in FL all my life and I dont think I've ever heard the term hurricane fencing.
I've had really good luck with cutting heavy wire with my gerber 800. I just dont see the need, personally, to have a wire notch.
It's also called chain-link fencing. That's funny, I always heard it called chain link fencing here as a kid and then heard it called "hurricane fencing" when we moved to Tampa Florida and that's what they referred to it as at school. I suppose it was called hurricane fencing because it would let the air pass through but helped stop a lot of the debris blowing in it.
Ok. I've always called it chain link fence. I guess its a coastal FL term.
I think it is just a "marketing" term...it's likely called whatever helps it sell better in whatever particular area it's being marketed in...it's also marketed as security fencing in some places.
most of the times I've heard it called hurricane fence was heights over 6'.
