Wood Perservative - anyone tried ....
Hi Guys.
I want to share my experience with the mixture.
The process of creating it was exciting for an office dude like me. And for security purposes i would recommend you have someone to give you a hand.
In my case it was my dad.
Its not difficult by any means, and i think i am able to do it on my own now, but the respect for the hot flamable liquid was quite tangleable.
I mixed the lineseed oil and terpentine replacement in a cleaned out can and added the wax. The melting procedure on a camping stove took about 5-8 minutes i would say.
I decided to leave it in the can to harden and not pour it into a glass container, even though that would surely look better. The cooling was surprisingly quick. I was able to use the resulting creme after about 4 hours.
Now the interesting part:
It does work ! And the resulting finish does feel very smooth. As suggested i added ample of the material in the first go and then used a clean cloth to work it into the surface. It did feel sticky right after applying it, but letting it rest over night the surface was quite pleasant to the touch. I wiped it again with the now semi clean cloth and called it quits.
The verdict:
For roughed up wood i would whole heartedly recommend the mixture. It seems to close small pores and gabs readily enough.
For already fine and polished wood handles.... i don't think you gain much over a pure line seed oil rub.
Still its a handy asset for the tool shelves and hey.. its quite cheap and homemade :) Certainly something not everybody has.
Been using this stuff called boos block. Its a mixture of mineral oil and beeswax. Seems to soak in to the wood nicely on most of my wood handled blades. My father used to use it to condition the butcher blocks in his shop. Not sure where to pick more up though.
keep us posted with your impression of the mixture :) sounds pretty alchemistic hehe
Will do, definately a feel of mad scientist while making it. I will echo Teclis22, anyone attempting to do this, do it outside and be very, very careful. A double boiler is a good idea, keep open flame as far fom it as you can.
I used a bit on a knife I am putting a handle on, it was sanded to 220 grit and coated with tung oil already, but it changed the feel a bit ( for the better) and filled in some of the small holes that I didn't sand away
I'm going to treat the handle of my UVK tomorrow and snap some before and after pics
The UVK before
After
Nothing dramatic, but it did make it feel, I don't know, creamier in hand, quite nice. And if it protects it from cracking, all the better
This mixture is pretty standard for gunstock finishing, I've used 1:1:1 BLO, turpentine, beeswax for years on wood. It's been in widespread use since at least the early 1900s.
I've used linseed oil/turpentine mixtures many times for maintaining the handles of wood tools, including khukuris. It works well. I also used it for my wood floors for decades and loved the look it gave. One drawback to the mixture is if you leave it on a rag in a heap, it can spontaneously combust.
The addition of wax to form a paste sounds like a great idea. I've never tried it but will have to give it a go sometime. The paste looks easier to deal with and less messy than liquid oil/turpentine mixtures.
Looks like a good mix but looks a little risky for my home. I'll stick with the tried and true King of wood oil: Tung Oil. I haven't seen anything better in 30 years.
If you have the panitece it will reward your family with generations of tough beauty.
I am an advocate of the best wood finish you can buy (as long as it's 100%). I only use mixtures like Formby's as a last coat if I want a high gloss shine. Stick with the best like Himalayan Imports.
I have been using she butter on my handles with good results.
The wood loves it and it stays on because it is so thick.
Cheap and easily available too.
Tung oil is quite excellent all by itself. I usually apply tung oil between sanding grits, to allow it to soak in. Nothing brings out the grain or burl like tung oil.
I do like to to a coat or two of wipe on polyurethane so help protect the final coat though
