lagarto said:
Robbie,
Check out a Vermont Castings, we had one for years, they put out an amazing amount of heat, although they do tend to go through wood...........................................
http://www.vermontcastings.com/content/products/products.cfm?category=16
Lagarto
+1 on the Vermont Castings! We've had one for years. We originally got it because this area had the highest electric prices(the only utility you could get for heating)in most of the USA.
But we got gas finally and don't use it anymore.
Another problem is the wood you use. Juniper is very popular around here as it's about the only thing the forestry allows to be cut for firewood, and it causes sensitivities, like throat and lung infections, bronchitis, etc. Wood stoves used to keep the doctors in business in this area, just prescribing antibiotics from November through May to 75% of people who used wood stoves.
My wife was among those that had problems. I got migraines and dizzy spells, as did three of my neighbors. One of them spent several thousand $$ on tests to determine the cause with no results, till she stumbled across a toxicologist who asked if she burned cedar/juniper etc. And told her to stop that. Her symptoms disappeared almost overnight, as did most of the people on the block when we heard her results and quit burning that type of wood.
If you get one, get a smaller one with a 6" chimney pipe, that takes 16" logs, versus 18" for the bigger models, as the regular sized stoves will drive you out of the area you have the stove in. I mean you can get a suntan from it.
When the inside of the glass doors turn black from burning, just use regular no scratch comet on a wet sponge to get it off. I tried every chemical I could find before stumbling on the comet as a last resort, and it works like a charm.
Good luck whichever way you go.
