XMP..this is exactly what I do. I supliment my heat with a wood stove.
Brands...nah...don't get too crazy with that. I bought my used on ebay for $50 because the guy wanted a flat screen tv and the wood stove was in the way.
That works for me!
I found a local handyman to install the single wall chimney and have had no problems for 5 years now.
Last year I got from a friend one of those heat reclaimers. They attach between the pipes and when it gets hot enough a fan blows from behind and out comes hot air. Does a great job heating the house FAST, but I found problems with it.
1. Need electricity to run the fan.
2. Creates TONS of creasote!
3. Kind of noisy.
You can see from the attached pics the creosote that had run down the outside of the pipe during a heavy rain storm. I'll clean all that up this summer when I take the pipe sections apart to clean. Get them re-painted too.
I was going to go the wood pellet way, but they too have problems.
From what I understand...if you want the pellets cheap, you have to buy them by the ton. Storage becomes a issue because you must keep them dry.
Also, you need electricity to run the auger that feeds the pellets to the stove. No electricity, no heat.
This is why I didn't go that route. I wanted to have available heat if I had NOTHING else. True, you need dry wood, but that can be accomplished with regular spring and summer work.
I am sooooooo happy I went the route I did!
If you want ambiance, you have have the doors open. If you want efficiency, you can close the doors and regulate the heat with the dampers.
They are nice, but there's work involved with them.
Hope I either helped or inspired you!
