Woodchuck Question-- Sand the Last Coat of True Oil?
I think I am nearing completion on the tru oil finish on my AK handle. Do I sand the final coat or just buff it out with a rag or something? Any help would be appreciated.
--Josh
buff by hand.
A good carnuba-based wax intended for wood (stuff for cars has a lot of additives) can help to protect the oil finish. Of course, the wax will need buffing afer use to maintain the best shine.
Thanks, firkin. Do you recommend finishing with carnuba wax over just leaving the tru oil as the final coat? Does the wax make the handle slippery?
--Josh
Josh, I use the wax. Walosi, the tung-oil-master, says Johnson's paste wax like one would use for wodden flooring works well. I use something made for furniature that appears to be wax flakes moistened with orange oil.
You can always use steel-wool to remove the wax coating and apply more tung oil later. Any residual wax seems to blend in, or get removed by the polishing steps.
Not slippery at all, actually a little tacky. People wax surfboards for grip. And skis for grip and glide. Depends on the different waxes and the temperature. I guess it's possible to be more slippery with some cloth gloves in cold weather though. I like the idea of the easily removable wax getting dirt ground into it instead of the oil. I like to checker or carve the wide ring in the handle to increase the grippiness anyway--like is done on the chitlangi or some of the older khuks shown in the FAQ.
