worden supreme?
Tell me what does everyone think of these? Ive read some of the old threads and it seems that there is a divinding line between, good points, and bad points. The worse it seems are comments on the liner lock failing.
what does everyone think, would I be waisting my money on the med. worden tactical supreme (11235) model?
:confused:
I owned two of the large version. On both the liner lock would hold tight if you snapped the blade into position by flicking it open but when you eased the blade open the liner would only partially engage failing to lock the blade open. I sold both.
I would recommend that you use the search function to look at all posts on this knife for the last year.
If you can only afford one knife and you have to actually use that knife, I wouldn't recommend the Worden.
Originally posted by K Williams
What's a Worden Supreme? Do you mean the WORTAC?
I believe the supreme is a small Wortac (2.9" blade) with wood scales:
dirtcheapknives_1713_62926499
I have no experience with the production version but the lock works perfectly on my large custom.
RL
