An "FRN Stretch" would be the closest to the Cento III. It has a thicker blade and the "Volcano" grip handle can't be beat. Personally, I like the thin blade on the Centofante III but I wish it had a handle like the FRN Stretch or Endura IV. When it comes to electrical work I like a pointy blade and usually go with the Native or Endura III. My Cento IV gets a workout at home when dealing with electrical stuff.I recently bought a centofante 3 and love it! Does anyone know of anything similar to this only a bit more heavy dutier. I am pretty rough on knives at work as a electrician. Any thoughts?
Spyderco will be releasing new versions of the Delica and Endura. Both will be full flat ground and come with steel liners. Keep an eye out.
For this kind of work, you would be hard pressed not to use a Gayle Bradley with CPM-M4 steel. That thing laughs in the face of copper cable.
I'd recommend an Endura4
the only thing that i dont think would be good is the thin hollow grind as a lot of lateral force can be applied while stripping large gauge wire
maybe a Gayle Bradley. that thing was built for work.
im also in electricain and tho i most often carry a plain edge i find that a fully serrated spydie works wonders for strippin the jackets and insulation off cables....the tenacious is a good beater knife at only 30 bucks you wont mind soo much is you loose or break it...if you want somthing similar but made in USA id say go manix , but def try out a fully serrated blade on the job... you will be plesantly suprised bu the performance in the field!!![]()
