Worker-Help Wanted
The scan of James' embellished Worker started me thinking. I came by a second-hand worker last week and I would like to refurbish it, maybe get it engraved or etched as a gift for one of my daughters. The scales are pretty scratched and unfortunately I don't have access to a buffer at the moment. Can anybody (Drew?) give me suggestions for using wet'n'dry to polish the sides? What grit would give a finish similar to the original factory finish? I noticed in the scan there seems to be sanding marks running lengthwise along the scale. I am concerned about the sanding water getting inside the knife, although I guess I can give it a good rinse when I finish.
Any suggestions would be greatly appreciated. My eldest daughter has her eyes on the knife already.
Take care,
Clay
Don't worry that the world might end tomorrow....in Australia it's tomorrow already.
You can use wet&dry paper and a hard sanding block to get a nice satin finish. Start with 220 grit, maybe, and see if that easily removes the scratches. Then switch to 320 or 400 grit for a lengthwise satin finish that won't show every fingerprint right away. Do the finishing strokes lengthwise, one-way, so you don't have scuff marks from the backstrokes. You can tape the blade and use it as a handle when you do the work. And wash out the dust.
- JKM
www.chaicutlery.com
AKTI Member # SA00001
Brian, James thanks for the replies. I haven't seen the Scotch Brite pads here, other than the green ones used for cleaning cookware. I do, however, have a large supply of wet'n'dry at work so I guess that's the way I'll go
I'm getting quite excited about this project. Now the search is on for a suitable inscription or design. Something which sums up the meaning of life in a short, pithy phrase
Take care,
Clay
Dang, guess I missed my chance. What they said, LOL!
I'm curious what's used to apply the original finish. I've had good luck with a gray ScotchBrite wheel, but it's definitely a finer finish than the original. Mr. Mattis' guess of 400-grit sounds about right to match the original look. But what puts that finish on in the first place? Japanese men with sanding blocks? A coarser abrasive wheel? A surface grinder maybe? Ah, the mystery...
-Drew
