Masteroffajitas
BANNED
- Oct 7, 2008
I want a machete for bushcraft, do you guys think that these knives are working knives? Or just pretty knives? Can you also post pics of them in use?
Or he can get a nice Sirupate or Kobra for the machete work, and an AK for chopping.
After all, who has ever bought only one kukri?
ETA, an Uddha sword would make a hell of a machete also. Even my Tarwar, albeit a bit heavy for the work, still makes the vines cringe when they see it.![]()
The difference between a good one and great one is all about how it fits your own hand and your own swing. There is a complex, subtle interplay between weight, balance, handle angle, and blade geometry that just seems to make some cut of them cut like light sabers. I don't think you can predict it, but if you start with a recommended beginner's model you'll almost certainly be happy with your purchase.
The traditional handle, with the ring in the middle and the bell at the end, might feel odd at first, but resist the temptation to modify it until you have used the kuk for a while. You might be surprised at how quickly this ancient design grows on you. (I do admit that I sand the sharp points off the handle bell, but I usually leave the rest of it alone).
Be sure to read the safety thread. You can really scramble yourself with one of these things if you're not careful...
In support of that advice, consider whether you're likely be working with protective gloves on -- a handle that seems a bit uncomfortable to hold in the house, can turn out to be ideal when outdoors in practical use.resist the temptation to modify it until you have used the kuk for a while
The more "workhorse" models ... either have a full tang with a slab grip or a fat kangaroo shaped tang that goes all the way through the handle and is peened over with a keeper. The term "bombproof" comes to mind![]()
Gotta love how the 'roo has replaced the rat.![]()
Aussie's will be proud!:thumbup:
No hoppin marsupial has replaced me.
My HI users are mostly choppers, but I'd suspect a 20" and under Kumar Kobra would be the prime choice for machete work. Generic machetes are typically very thin (though sometimes very weight forward), so even a medium sized kobra is going to seem thick by comparison. I have a 25" Kobra, but that might be oversized for machete work. I couldn't see myself swinging it through brush for hours worth of hiking.
The problem I have is trying to convince her to convince the Kami's that a 5/16ths spine is not too thin by any standards except HI's!![]()
Nor could it!
I have emailed Yangdu about having a custom 23inch/30ounce Gelbu Special made as a machete replacement. The problem I have is trying to convince her to convince the Kami's that a 5/16ths spine is not too thin by any standards except HI's!![]()
That would be a very desirable and useful specification, imo.I have emailed Yangdu about having a custom 23inch/30ounce Gelbu Special made as a machete replacement. The problem I have is trying to convince her to convince the Kami's that a 5/16ths spine is not too thin by any standards except HI's!
... I would guess it's both so that the khuk will last a lifetime...
My 20" Sirupati is 7/16" thick next to the bolster and tapers to 1/4" near the tip. Works great as a machete.
Heber
That would be a very desirable and useful specification, imo.![]()
