Working Pearl
Okay, I'm about to try to use some nice black lip pearl, but I've never worked with it before. What do I need to know? I'm going to cut a diamond shape that will have a 1/16" pin in each corner. This will be an overlay on a relatively large (compared to the pearl) flat surface.
My idea is to drill the blanks first, then tape them back-to-back with double sided tape and cut the diamond. Dremel cutoff wheel?? Then bevel or round the edges and glue them down.
But I don't know whether the Dremel is the way to cut them (abrasive wheel? or saw?), or what grits are appropriate for pearl. What are your methods? Do I need an unusual bit? How likely is it to chip out when I drill? How do you minimize the chance of that? One chip and I've blown my only set of expensive pearl blanks. :eek: Is pearl heat sensitive when shaping or buffing?
Please help me not screw this up! :D Thanks, I'm off to prepare the surface.
You can drill MOP with a regular drill bit, but feed slow and keep your rpms SLOWER. It's quite soft believe it or not, but will chip out fairly easily. You can use a 120 - 220 grit belt for shaping and roughing. Always leave it thick and sand it flush when insetting. becareful to keep it cool as a fast belt speed will burn and ruin your piece.
When working pearl, Sharp is the word.
New belts, sharp drill bits, sharp tools. Go slow, don't get it hot. Wear a respirator.
I saw the pearl to shape with a jewelers saw, or grind it on a lap. A Dremel will work if you have a steady hand. Use a new cut-off disc, and a slow speed (if you have a VS Dremel). It sands and polished easily.
Stacy
Thanks gents, that's just what I needed to know. Dang Stacy, thanks for the respirator reminder, I think that convinced me to use the jeweler's saw rather than a cutoff disk. :eek:
If I get up the huevos to go do the pearl tonight, it'll be the first time I finished a knife in one weekend... Well, I guess it won't be finished because of cure time but you get the idea. Maybe I'll use fast epoxy. ;)
Thanks again,
