- Nov 28, 1999
I don't work with 5160 very often, but every time I do, I question my methods. Just seems like that blades don't get hard enough. Maybe I'm used to blades getting super glass hard(O1, 1084). Or, maybe I'm on crack. Who knows?
Anyway, here's what I did the other night. Both blades are 5160, but the bigger one was Aldo's 5160H. I set my Evenheat oven to 1525(which means it fluctuated between 1520-1530), allowed the oven to stabilize for 20 mins or so, then put the blades in and shut the door. I allowed them to soak for 15 mins or so and pulled the small one out and did a full quench into Parks AAA. As the oven lost some heat when I opened it for the little blade, I allowed the big blade to soak for another 10 mins or so, then full quenched it into the Parks AAA. Wiped them down and took a fairly new triangle file to the edge of the bigger blade and it sort of dug in. I mean, it made the higher pitched ringing sound of a hardened blade, but still it dug in a bit. I know on my O1 and 1084 blades, that file isn't digging in at all. My question is, do I need to reheat treat this blade; maybe soak at a higher temp? Maybe quench into the Parks 50? Is this normal for 5160? Was my file digging into decarb? Or, again, am I on crack and is my file just extra sharp?
Little blade seems very hard and will not bend or flex at all, despite being flat ground very thinly. Didn't try the file on it, though.
Oh mighty 5160 experts; I seek your knowledge!
