Last spring I bought some fake marble handle scales and Im now getting around to using it.
Being some sort of plastic compound it cuts, drills, and sands easily. Knowing that if there isnt a picture, it didnt happen, here is a picture of the glued up knife. Pretty amazing, huh?!?!? ;-)
Though it is a plastic and is quite soft, it is at the same time brittle. When you drill a hole in it you better have it backed up with a piece of wood or you will probably get a fairly large blow out where the drill exits, as seen in this ¼ lanyard hole.
It also stinks like burning plastic when sanding or drilling it.
Before gluing it up I started roughing it out with a rasp and quickly noticed that I was shattering the material more than doing what rasps normally do. Unfortunately I ended up with a small section on the bottom of the tang where it exposed the flat of the tang. I filled it with epoxy and hoped for the best.
Soooooo After the glue cured and working a lot more carefully, I shaped the handle using a slow 6x48 belt sander/grinder and careful application of a rasp and coarse file, then I sanded it. The sanding went OK through the 400 grit but when I went to 600 grit I started getting streaks of stuff on the handle. Talk about a heart attack! I thought I had managed to put a humungous gouge in the plastic, but it was only on the surface.
Hmmm What could be causing this??? Clean fresh sandpaper so it wasnt something left over from something else. I decided that maybe it was a combination of the extra fine grit and the extra fine powder it makes along with the heat of rubbing might be causing the dust to melt. Its a theory. I took the knife to the kitchen sink and used the 600 grit under cold running water. No streaks of stuff. I went to 1000 grit under running water and a little soap and still no streaks.
This is a picture of the handle as it right now. I intend to put a brass tube in the lanyard hole yet, and I see magic scratches that mysteriously appear after you think youre done and take a picture of your handiwork.
Ive never use this handle material before and I am not satisfied with the finish that I have on it. This picture shows that the surface is not shiny but dull. You can also notice a bubble and see how shiny it CAN get on the inside of the bubble, or on the previous image of the blown out lanyard hole. You can also see where I filled a void with epoxy.
I suspect the solution is pink scratchless compound on a buffing wheel, except I dont have a buffer. Is there a way of polishing it by hand? How can I get it to look nice and shiny without a buffing wheel, or is that not possible?
- Paul Meske, Wisconsin
