working with ivory
Any tips for working with narwhale tusk?
I have been told that it will crack all the way through along the spirals. Will stabilizing it help?
what about walrus tusk?
If I remember correctly, it is illegal to even own Narwhal tusk. You might want to check into that, so you don't unknowingly, find yourself in a world of problems.:confused:
Stabilizing would be my guess. New belts, slow speed, or really be careful not to overheat, if you can't slow the grinder down. :eek:
I have never used either one but use sharp everything to prevent overheating. New drill bits and belts. Go to 2000 grit to keep buffing to a minimum. Small cracks will show up later on all surfaces that got too warm. Take your time. One more thing....Ocean ivories make very fine dust. Work outside. Stay healthy.
Canada may have different laws than the USA. These ivories may be fine to own there.
A person can buy and sell narwhal tusk in the US only if they have the proper paperwork proving it was taken before 1972. In Canada I do not beleave there are any restrictions on its use and trade.I have repaired and carved a little narwhale . For a stick tang handle if it is the proper size it is best left natural.It is one of the most valuable of the ivorys .If walrus ivory is aged properly it does not usually crack.Just watch the heat.
Chuck
thanks for the tips.
I knew it was ok for me to have and work the ivory, i just cant send it out of the country.
