I've gotten to the point that I'm getting enough really rough blades that I want to be able to remove metal much faster. I don't want to sharpen everything on a powered system, but I want to use it when it's appropriate. Like on Chinese kitchen knives that have been abused for years without ever seeing a stone. Like putting a new edge on a bowie knife that's been used for digging, batoning, etc.
The WorkSharp seems like a great solution since it's small, portable, inexpensive, uses very inexpensive belts, and seems like it can take off plenty of metal. I'm actually worried that it might be too fast. I'm going to practice on cheap knives I don't care about, so I should be able to get the hang of it without hurting any good blades.
I'm envisioning using the WorkSharp like a regular belt grinder: That is, sharpening using the part of the belt that moves downward, with that belt facing me. Moving the blade, edge down, right to sharpen one side. The flipping the blade over, edge down, to sharpen the other side. The only thing is, the belt is angled and not straight up and down, which I think is going to make estimating an edge angle more difficult. Does this sound like a decent plan or have I got it all wrong for this machine?
Should I wait on the Ken Onion edition? It's most appealing feature to me is the variable speed, which I'm thinking could limit the grinding rate, making it longer to grind off metal, and therefor safer for the blade. I don't know much about power grinding metal; I'm just making educated guesses.
Is there something else I should consider? I don't have a dedicated shop area, so this will have to be packed away and then brought out and set up to be used. Even if I did have a dedicated shop, I don't think I'd want the cheap Harbor Freight 1x30, as it seems too sloppy and I'm not really up for doing DIY mods to make it "good".
Thanks for any help and wisdom.
Brian.
Brian.
