would love to see a Team Hell Razor Gemini LB...
After looking through tons of hog feed the idea came to mind.
what if there was a THRGLB?!?!
1. hell razor blade.
2. tean gemini double guard.
3. light brigade handle treatment.
4. straightened hell razor pommel.
if you're seeing what i see in my head then you probably just sprayed your shorts right now. :emot-yarr:
I like sHELL outta this idea!!! Minus the double guard. Can I have mine in the Knob Creek full flat grind edition?
Can't see messing with PERFECTION, lite enough as it is!!!
I'll second that " PERFECTION " ! ! Although I wouldn't mind seeing a heavy duty version :) maybe .20 or .22 ish lol :thumbup::)
I'm a fan of the Hell Razor as designed. I don't think it needs any improvements.
I'd like the flat ground Hell Razor, and a flat ground, Skinny TGLB.
Good luck with that. As I stated previously, the HR is pretty much the perfect blade as designed. There aren't many Busse designs that I like as much as I like the Hell Razor.
Fix the flower butt (make it straight like a sarsquatch) and make it a dagger blade with corrugations on both side and wowie wow that would be something :)
You read my mind David:D Maybe even make the butt/pommel come back around on both sides like the Gladius handle does! THEN............wow!!:thumbup: I would be all over that!! Basically a mini-Gladius with the corregations!!!
the double corrugated dagger sounds damn good!...shouldn't there be a sticky with just tons of photoshopped ideas?
of course its great to see the real deal but i think its cool to see what hogs are thinking for variants or customs...hell jerry might run with some of the ideas.
that would rock!
A dagger out of the TG would be awesome (as long as they'll ship to NY or I can get a proxy :D). CF would be a must though.
