Would tantung out perform talonite?
Now that I have a few specs for this stuff, I would like some opinions as to performance. One link to some specs is:
www.vrwesson.com/pg4.htm
Tantung is a cast alloy cutting tool material composed principally of chromium, tungsten, columbium, and carbon in a cobalt matrix. These elements combined in the proper proportions and cast in chill molds give Tantung its most important characteristic -- the ability to retain its cutting hardness at temperatures of up to 1500°F. It is neither high speed steel nor carbide. It is unique.
Tantung has a high transverse rupture strength, low coefficient of friction and excellent resistance to corrosion. It is tough, readily absorbs shock and impact, and is non-magnetic...it likes to work.
As a cutting tool, it is ideal for all turning, facing, boring, milling , and cut-off applications on nearly every type of metal as well as non-metallics. Tantung performs best at speeds of 100-250 SFPM and can be used to excellent advantage on machines where speed, power, and rigidity are limited. In addition, it will not anneal or lose its cutting edge as will H.S.S. when subjected to high-red heats generated during the cutting cycle.
Tantung G is recommended for general purpose machining of both ferrous and non-ferrous metal and general woodworking operations. For catalog items, Tantung G Hardness is 60 to 63 Rockwell C and Transverse Rupture Strength is 300,000 psi minimum.
With a higher RC than talonite, and non-magnetic properties it sounds like a possibility for an EOD (Mission) style of knife. I wonder if Kit Catson or Mission or anyone else has tried this stuff out. Comments anyone? I know Rob Simonich and The ever present Bald1 have some hands on with Talonite. How would this stack up?
Sam.
I think it will hold an edge longer than Talonite, but my earlier brief experience with it makes me think Talonite is tougher. Tools as they make from Tantung are heavily supported on the edge such as lathe bits. (see post on what is Tantung)
www.simonichknives.com
