I need to fix the bevel angle on 3 blades on a Bear MGC medium stockman.
I want to take the beginning of the secondary bevel back quite a bit.
Will this file do the job?
The Crescent Nicholson 21867N 6-in flat double/single-cut bastard file with an pattern is ideal for machinists, machinery builders, ship and engine builders. The file can be used effectively by repairmen and others who require rapid removal of metal. Its rectangular cross section allows you to smooth and sharpen straight surfaces, while slight taper in width towards the file's point creates ease of access in slots.
Bastard cut, pattern flat file
Ideal for machinists, machinery builders, ship and engine builders
Can be used effectively by repairmen and others who require rapid removal of metal
Rectangular cross section allows you to smooth straight surfaces, while the tapered point accesses slots
Double-cut on the sides for rough filing and single-cut on the edges for a smooth finish
Designed for use during jobs that require rapid metal removal
Great for machinery, ship and engine builders? "
I just need to get something today and it's at Home Depot so quick and easy pickup.
Thanks!
My plan on the fixes:
Thanks!
