WOW!!!!!!
Check these pictures out of the file work Alan Folts has done on the pass around bowie!!! Man, is that some fine craftsmanship or what!!!!!
<img src=http://members.aol.com/l6steel/ebay/passbowie.jpg><img src=http://members.aol.com/l6steel/ebay/passbowie2.jpg>
http://www.nebsnow.com/L6steel
Wow! Great work! Alan, how do you get the black in the recesses of the filework?
jj
Alan, if you're reading this, that is absolutely beautiful work! Can you tell me what types of files you used for this job? I assume a round chainsaw file for the larger cuts, but what about the small cuts?
My Knife & Sheath Pages:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
Sheath Makers Referral Directory
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
I'm depressed....
Really nice Alan!
Jerry Hossom
www.hossom.com
Actually its not "file work" I preffer to carve the spines of my blades AFTER heat treatment. I use various accesories for a flex shaft rotary tool and cut the hardened steel. I feel working it in the hardened state, the rotary tool cuts much smoother and tends to dig in a lot less than it would in soft annealed stock..
On to the how to's, that pattern is done with a 1/2 inch sanding drum with 50 and 120 grit bands, a thin non reinforced cut off wheel, and a couple of those little sanding discs, the 50 grit drum cuts are centered every 3/8ths of an inch and are cut about 3/32 from the opposite side. Then the cuttoff wheel is used to take out the stock for the little "branch" and to take out a little material for the blend. Then I switch to a 120 grit drum and sand the scratches the 50 grit monster leaves, and that is also rolled back over the back side of the depression to complete the blend on the back side of the dip. The last step is to use the sanding disc to clean up the cuts above the branch. And if you arent going to fill it, sand as needed!
The nice thing about this patern/proccess is its FAST, on a normal 8 inch fixed blade I can get all the cuts into the spine in about 5 minutes, with files I would be there all day...
I never asked but my thoughts were that this meathod would cut down on stress risers in the steel, but would also be sorta touchy about overheating the spine area of the blade when doing the work??? Am I crazy or what?
Thanks for all the compliments, and I hope I described it so some of you can duplicate it!
Alan Folts...
If a Man talks in the forest, and there is no Woman around to hear him, is he still wrong?
They be nice Pilgrim! very nice...
Really adds a lot to the knife, I had a Jay Harris folder with Vine pattern on the metal spacer, but it wasn't this nice!
G2
"The Road to Hell is Paved with Good Intentions!"
Take the time to read your Bible Now, don't be left behind...
G2 LeatherWorks
Alan,
GREAT work! I am impressed. I wish my hands were that steady.
I get it next to regrind the blade and give it a hand rubbed finish. I can't wait to see that filework up close.
Barry
Jones Knives
"For DUTY and HUMANITY!"
Curly, Moe, & Larry
I wondered when someone else was going to figure out my Filework secret ,I used to do all of it with a file now I use the same technique only I go back over the cutoff wheel cut's with a small triangle file but I still do it all before HT to get that black effect in the cut's ,Great Job Alan ,look's like your a little more Proficiant and exact than I
TbarK Custom Knives
http://vip.hpnc.com/~tbark Therefore I erge you brother's in view of God's Mercy to offer your body's as living sacrifices holy and pleasing to God-this is your spiritual act of worship Romans 12-1
