- May 24, 2018
Recently made an estate purchase: Case Sodbuster 2138 Case xx usa 1970- 79 according to tang stamp, but no dots are visible, peculiar as not known if they are under the handle or a pre-dot. Knife in apparently unused condition, never sharpened, no cracks or scars, brass is bright most likely polished by estate folks.
It is beautiful but seems to have a build flaw. The snap and stay at open is very weak. I have others from the 70s and 80s eras and they snap and stay open with authority. Have a few recent ones of same model that are anemic in comparison, and of course are not built husky, with thick blades and springs like the old ones.
This one is even more anemic than the new models. Bought this for an everyday user, but am fearful of blade closing. I thoroughly degreased the hinge, but no change.
The problem appears to be the tang pivot pin location. When knife is open the tang top edge sits below (maybe 1/64) the mating edge of backspring, which is perfectly flush with liners. This leads me to believe that the blade was drilled a bit high on the tang, creating too much gap between tang flat and spring flat.
Called Case and the lovely CS person said to send it in for review, the tech will look it over and determine if it is a manufacture flaw and if it can be repaired. She said they retooled in 1990 and do not have parts to repair pre-90 knives.
I am unable to come up with a fix besides complete disassemble and redrill fresh handle/liners to replace pin. Any thoughts on repair method would be appreciated, and thoughts on value of sending to Case. It is painful to mail it as I don’t know what they could do, maybe replace it with another new one that unfortunately is not in the same league.
Note: Initially thought to put in maintenance category, but think the Traditionals group might be more experienced with these matters.
