- Jul 7, 2016
Alright so I unboxed the blade grinding attachment for my worksharp yesterday, and figured it out pretty quick and got right down to work practicing on some cheap knives. All was going great until about halfway through the progression on the second knife, the belt started wobbling, enough to where it was pretty hard to keep the blade steady on the pull across. I've never used a full size belt sander before, but from what I've read and watched about them, a little belt wobble is not uncommon, so I figured that I should just work through it. Well the wobble has continued to get worse, I have been endlessly adjusting the tensioner and the belt tracking knob but no luck.
I believe that the hub fastener (the knob that attaches the BGA to the actual worksharp) is causing the significant belt movement because the edge of the belt is making contact with the inside of that fastener, and that seems to be knocking the belt off track but I'm not sure if that's the problem. I'm wondering if anyone here has experienced a similar problem and if there is a solution? Feel free to ask any clarifying questions if I haven't described my problems clearly enough
Thanks a ton
Sent from my iPad using Tapatalk
Thanks a ton
