SR Matt, I have yet to find a knife with both sides ground to the same degree. If they're out there, great, but I've never seen one yet.
Probably the best thing to do is get a selection of wet/dry from 220 through 400 (220, 280, 320, 400). Cut them into strips at least as wide as all three sides of the triangle stones. Cut the paper along the 8" edge, not the longer edge.
Now, you can carefully (creases and tightness-to-stone are important here) fold them around the stones and clip them with black binder clips, small spring hand clamps, or even tape.
This will grind your edges even much faster. Using the medium stones is futile in my opinion. I've used this method on at least 5 knives (probably more but I'm just sitting here guessing) and it works very well.
The reason I say cut the strips
at least as wide as the stones is because: once you use the front face of the wet/dry, you still have two unused sides, BUT!, you can't use those sides unless there is a little more paper to go around the unused side of the stone to be clipped with.
Now, this will regrind the edge bevel (NOT "re-profile"- improper terminology [useless trivia here
]) your edge to either 15 degrees (30deg) or 20 degrees (40deg). You can increase the 15 degree to 12.5 if you want. You take a 1/4" small piece of wood and place it under the Shaprmaker base. Use a protractor on the bench and sighting by eye, move the wood inward or out to get your 12.5 degree angle. Sharpen ON THAT SIDE only until it's nice. Then, use the protractor again and get the other side of the base adjusted to provide a 12.5. Note that, since the holes are each placed on opposite sides of the base, the wooden wedge will not be in the approximate same place on the other end. Use the protractor.
Now that your knife is ground at 12.5 (this is an example, you could choose any angle, steeper or more shallow), now you can remove the wooden wedge, remove the wet/dry, and you have a knife edge bevel of 25 degrees. Using the 30 degree medium and fine rods to place a nice, clean micro-bevel on the edge. Works good. I've done it as I said at least five times.
The Spyderco diamond stones run about $60...maybe cheaper here or there. The wet/dry setup will cost you $5.
