WTS Reeves Project 1 and Shadow IV, Surefire Delta EW-04,Gerber Applegate $65-$355
All are in New/Unused condition. Reeves knives come with original boxes and paperwork. All prices include priority mail shipping.
Project 1: $325
The Project I (spear point blade) was designed in conjunction with Sgt. Karl Lippard, USMC and author of "The Warriors - United States Marines". The concept was to fulfill all the features which Sgt. Lippard felt were vital for a knife carried by a Marine. The 7.5" blade is perfect for chopping, digging and cutting, with sufficient weight up front for maximum strength and ideal balance. The wave serrations on the cutting edge are designed to cut easily through nylon cord or harness. The 2" cross guard has a night index which tells you by touch which direction the cutting edge is facing. The Project II has all the features of the Project I but has a traditional clip point blade.
Shadow IV: $215
Designed to incorporate the two basic criteria required in knives destined for hard field usage, these spearpoints have plenty of blade weight and good strong points. This design has been used by professional soldiers all over the world who have found them to be extremely good weapons as well as rugged dependable tools. The Shadow III is a good everyday carry knife and the pancake sheath rides high and snug. The slim, symmetrical sheath supplied with the Shadow I and Shadow IV has a strap which snaps over the cross guard and that can be moved to allow left-to-right or right-to-left closure
Surefire Delta EW-04 (2 available): $355 each
The Delta folding model is a rugged but lightweight combat/utility knife. Its superb fighting capability is maximized by its Crucible CPM S30V blade steel, renowned for strength and edge retention, and by its brutally tough 1/8"-thick titanium frame halves and liner lock. The frame incorporates a number of practical tools — screwdriver, wire cutter/crimper, parachute cord/seatbelt cutter, wrench, and self-seating wrench slot for smaller nuts, and also features a reversible pocket clip. Whether you're heading into battle or into work, you'll find the Delta folder an indispensable companion.
FEATURES
• Blade is blasted with silicon carbide, coated with tungsten diamond-like carbon, top-coated with CVD diamond Emergency cutter for seat harnesses, webbing, parachute cord, etc.
• Frame piercing provides 1/2" hex wrench and toothed slot for loosening smaller nuts down to 13/64" size
• Hardened 440 stainless steel window breaker
• Cutter/crimper accepts up to 12 gauge wire
• Integral finger guard ground for use as a screwdriver vOversized blade opening hole and disk for use with gloves
• Surefire Delta has a Low-profile reversible wire pocket clip
• Length Closed: 4.7 inches
• Length Open: 8.0 inches
• Blade Length: 3.37 inches
Gerber Applegate Combat Folder: $65
This is the original Applegate-Fairbairn folder offered by Gerber. This large Combat folder is the collaborative effort of Colonel Rex Applegate, Bill Harsey and Butch Vallotin. This large folder was designed for military and police type applications. It is sturdily constructed with full stainless steel liners and a sturdy liner lock mechanism. A tough ballistic nylon sheath comes with the knife and is designed to allow carry in either an up and down position or a sideways position. A right / left thumb stud system make this knife highly functional for right or left handers.
Technical Specs:
• Overall Length: 10.06''
• Length Closed: 5.6''
• Length of Blade: 4.25''
• Weight: 6.3 oz.
• Lock Mechanism: Liner Lock
• Blade Style: Double bevel, Serrated edge
• Blade Material: 425 Modified Stainless Steel
• Handle Material: Fiberglass filled nylon
• Sheath: Ballistic nylon sheath with optional horizontal or vertical configuration
Do the Delta's have the disc above the opening hole for opening with gloves on?
Also, do they come in the aluminum case with handle or the cardboard box? Thanks!
Neither Delta comes with the original box (priced accordingly).......wife got rid of the boxes during a cleaning fit. Both have the opening disk.
