- Sep 27, 2017
It's kind of an oxymoron -- to get the knife to smartly flip, you need a strong detent. The way to prove this is to open the blade to where it is just slightly past the detent and then try the flipper. The blade moves easily but won't flip open beyond 90 degrees. And yet, sometimes this strong detent prevents being able to apply downward pressure on the flipper. Not only does that sharp edge on the flipper hurt my finger, but the blade doesn't budge. IMO, this occasional lockup has nothing to do with the tuning setup on the knife, but is in fact a product of the detent kind of getting stuck in the hole in the blade. On a loading scale, I've measured the amount of force necessary to open beyond the detent and it is close to 1 lb, 13 oz.
From an engineering perspective, the recommended way to flip open the knife (simultaneously pushing down from the top while pushing forward on the flipper) is at odds with pure physics. You are going to get the best mechanical advantage by placing the tip of your finger in the concave portion of the flipper and pulling back fast. Do it in slow motion and you'll see what I'm talking about. However, while this is the easiest way to get past a strong detent, it will not result in the desired snap action. In fact the blade will only open about 135 degrees. This is where I apply a slight flipping action with my wrist, which I am completely used to doing on my big folder, and the blade flys open with a solid snap. The important thing is that it NEVER fails and it is much much less painful on your index finger.
I realize my method is going to create a stir with the XM-18 purests. Putting my flame suit on.
