Put a new Ti scale to replace the G-10 with the liner and am now facing a dilemma.
If I keep the pivot screw loose enough to be able to flip it open without a wrist movement, there is is a noticeable side play in the blade.
If I tighten it (with a thumb nail) enough to eliminate the play, the baled does not move as easily. I can still comfortably open it with the studs or by flipping with a wrist, but not just with the flipper as I used to be able to with the original set up.
Is this normal or have I possibly missed something when reassembling? I did put the washers back, but am not sure if I did that corectly. I notice that one side on the washers felt smoother. Should this smooth side face the blade or the scales?
I am new to Hinderers.
Thank you in advance
