Not to poach this thread too much, but...I received some standoffs(blue, bronze and plain) in a trade, all said to be Ti. How can I tell if the plain ones actually are Ti? I used the magnet test and they were not magnetic, but now I'm skeptical. Thanks
If you can be sure that you can eliminate any air pockets do this:
Weigh them, then submerge in water of a known volume. Measure the increase in volume. That is the volume of metal. Ti is 4507 kilograms per cubic meter, or 4.507 grams per cubic centimeter. 1 cubic centimeter is equal to a milliliter.
Anyone wanna check my math?
Another question. Is the standard clip on an xm-18 titanium or stainless?
The standoffs are made to the same overall dimensions irrespective of material, the steel and titanium standoffs will displace the same volume of water and therefore are the same volume.
Only the weight will differentiate the two and being the same volume the titanium will have a lower density.
Visually the stainless standoffs are more white and bright metal, the titanium standoffs should appear more grey and less bright.
I guess i assumed that people would understand that im getting at density. You need to weigh them then figure out their volume to get the density. Once this is done you can determine if their ti/steel. d=m/v
Do the latest generation of 3" XM-18s come with titanium standoffs on a standard configuration?
Thanks,
Brian
