- Mar 30, 2015
Which do you prefer, the Fatty XM-18 or regular 3.5” XM-18? For those of you that own/ed both your input would be appreciated. Thanks
Thank you for your reply. I’m currently contemplating picking up a Gen 6 Fatty wharncliffe because I missed the previous run of 3.5” wharncliffes and my biggest concern is the cutting performance. I guess with the thicker blade stock this confirms it.Just sold a Fatty. The Fatty Spanto is cool.
But adds almost no thickness to the tip compared to the XM 3.5 Spanto.
Therefore. Besides the cool factor it's not a win for me regarding durabily. It's more of a loss in cutting performance for pure awesomeness
I find the Standard 3.5 Spanto is the best. Thick tip with the same cutting performance as a spearpoint.
@Tacticaltater
Whatcha think?
Another great reply. Thank you for the informationI'm not a fan of the fatty, my 3.5" spanto is plenty thick behind the edge as it is, and I couldn't imagine how thick the fatty is. I had an XM-24 (which has the same stock thickness as the fatty) for a while, but sold it when I got my Fulltrack because I like the cutting geometry of the Fulltrack better.
It’s good to hear that there’s only a slight felt difference between the two as far as cutting. I understand that Hinderers are not very thin behind the edge to begin with (POU). Does the Fatty deploy slower due to the thicker, slightly heavier blade stock?Personally about the only time I can tell much of a difference between the Fatty and Regular XM-18 3.5" is when I am cutting up an apple. Outside of that they both perform about the same in my daily task of cutting up boxes, tape and the occasional rope.
And get ready for the Skinny 3.0s..
I've never had a Fatty and likely never will as a thicker RHK blade holds no appeal for me at all. I currently own 4 Hinderers and have re-profiled two of them--XM 3.5 Spanto and MP1--to make them better cutters. My HalfTrack will get the same treatment when it's time for a sharpening. My XM24 Spanto went off to Josh at REK for a radical re-grind and came back with a large-radius high hollow that cuts like a lazuh now.
I'm pretty happy with the RHKs I have now, but should I get another it will almost surely be a Skinny!
...and just because I never tire of showing this one off....
Almost a full ounce lighter!
