- Sep 27, 2017
I've had my XM-18 apart, cleaned and lubed, re-assembled and have spent a lot of time trying to find the sweet spot to give me the best flipping action. Found that I was at quite a disadvantage without have the spanner tool, so I ended up buying one from Rick. Not cheap, but a beautifully made precision tool that really helps if you are going to go through this process. It is the spanner side that you need, as a simple penny works well on the slot side.
I found that the sweet spot is "just this side" of the pivot screw having all the play (or slack) removed. So I guess there is still a tiny bit of slack, but I really can't feel it. Sorry. but that is the best I can do to explain it.
Now, while the blade will flip open relatively easy without moving the knife, I like to also flip my wrist outward (at the same time) to get a nice solid snap out of it.
I do have one question from the brain trust. I have read and also experienced myself that the thumb studs will not work with the blade closed. There is simply too much detent to overcome. Is it possible to lessen the detent ever so slightly? If so, how?
