Xtreme Concealex sheaths
Gollnick
Musical Director
The postman delivered all three today just as I was leaving for the famous Beavercreek Road address in Oregon City. So, I took 'em along and we looked at 'em there.
In the past, I've sort of stayed away from Kydex/Concealex for four reasons:
First, most sheaths and holsters I've seen seen have way to much material and this material is so stiff that it's hard and uncomfortable to wear.
Second, rough and sharp edges that make such sheaths and holsters uncomfortable to wear and can even tear clothing.
Third: overall really poor workmanship. This Kydex/Concealex stuff is just to easy to make a basic shape out of. It seems that anyone with a hairdryer suddenly thinks they can make a sheath.
And, finally, retention problems. When a material is basically rigid, it's gotta fit just right. A touch to loose and the knife/gun will fall right out. A touch to tight and you'll need The Jaws of Life to get the knife/gun out.
So, those are the four key points I'm looking for in trying out Clay's sheaths.
I'm also not a big fan of neck knives for two reasons:
First, I usually wear my shirts tucked in.
Second, I don't like a heavy thing hanging around my neck.
But, I recently saw a great idea: A neck knife sheath worn as a very simple, very brief shoulder holser with the knife actually under your shoulder, not hanging in front of your chest. This would be a good way to carry a knife at the gym, I think, so I'm eager to try that.
Well, the string provided on the Clay's neck sheath is a bit to short for this. In fact, I've seen Clay a time or two and I suspect that this string is a bit to short to get around his neck even. So, I'll have to round up a longer string. That shouldn't be a problem. In fact, I'll put my locker key on the same string. Very good.
Clay's neck/shoulder sheath is very minimal, which is just what I wanted and answers my first Kydex/Concealex objection. The edges are very nicely finished, very smooth. For a sheath that's gonna be worn right next to my body, this is excellent and answers objection
number two.
This proposed application here, at the gym, points out one of Kydex/Concealex's big advantages: they are plastic and impervious to water and sweat. Not only will they not be damaged by moisture, but won't absorb any odors, etc.
The big question is retention, especially in a sheath that will be used during moving activities. As I stated in objection number four, Kydex/Concealex sheaths must walk a very thin line between to loose and to tight. I gotta tell you, this sheath is tight right now. Not quite Jaws of Life tight, but tight. Now, the last neck knife sheath I evaluated was so loose that you couldn't jump six inches up off the floor and land on your feet and not have the knife fall out of the sheat. So, this one is a lot better. I also suspect that this sheath is going to loosen up a bit with use. Each time I pull the knife out, some small black plastic shavings come with it. So, I suspect that this thing will be fitting much better shortly as the sheath and the knife get better acquainted.
I hope so since I think this is going to be a comfortable, light weight sheath to wear under the shoulder at the gym.
The horizontal belt sheath is the one that appeals to me most for regular use. First of all, I love the belt clip on this thing. It flips open so that you can put it on your belt without removing or even opening your belt. Then, it snaps shut to assure that it doesn't fall off of your belt as some spring-clip designs can.
The fit-and-finish of the belt sheat is much the same as the neck sheath: excellent. The design is very minimalist, very non-intrusive. The edges are nicely finished. Everything is smooth and nice. This is Concealex done in a sensitive way that is not going to shag cloths or scratch the wearer.
Again, this fit is tight. But, I'd rather have a tight fit than have my BM42 fall out and be lost.
My only object to this sheath is its thickness. It's over 1.4" thick and ends up hanging off your belt just a bit.
Finally, there is the now famous Inverted V. Neck knives are nothing new and balisong users have been carrying in horizontal belt sheaths for years. But this Inverted V thing is nothing if not Extreme. Only Clay could come up with this rig.
Again, workmanship and finish are excellent. All edges are nicely finished. There are no sharp corners or sharp hardware to snag or scratch. Very nice.
Again, the fit is tight but the alterative to that is unacceptable.
Finally, I do have to say that this thing is remarkably more concealable and more wearable than I originally expected.
Most pants have a belt loop right in the middle in the back, but Clay has thought of that making the belt clip on this sheat a split design to actually utilize that center belt loop to keep the sheath centered. But, the first pants I put on this morning have an exagerated center loop and wouldn't work. But, I have learned over the years that not all sheaths/holsters work with all cloths. It's just something to be aware of.
In short, I am very impressed with Clay's workmanship. His quality and his finish are excellent. I'm looking forward to using these sheaths.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
Mr. Gollnick,
I have been playing around with a couple of Clay's sheaths for a few weeks now and wasn't quite sure what/how to say about them.
I am glad you created this thread! What you said was well phrased.
I am partial to the inverted V and have found that after a brief break-in period you come up with a very fluid draw.
I look forward to future updates as you and your new friends become better acquainted.
"Catch you on the flip side"!
Actually this is kinda wierd since I got mine in today as well but so far I have to agree these things are definitely worth it.
Mykl
Don't think you are...know you are.
I think I'm am the first person to own one of Clay's shoulder holsters and I must say I truly love it. The quality is excellent and it feels really nice hanging under my arm. This sheath is different from the rest because it holds the Bali by the tang(horn?) and the base where the latch is. You remove the bali py pulling out and down and this motion pops the latch for you and allows you to start flipping quickly. Under a jacket or coat it is not really noticiable (even with a bali that is 6" closed) unless you are looking for it. I know I keep saying I'm gonna post some pictures but the poloroids I have are terrible and someone else has the schools digi cam checked out right now. I have to agree however, Clay's sheaths are some of the best I've seen, and like an American Express, I never leave home without it.
Chuck,
I have 2 BalisongXtreme sheaths :
- a belt sheath (with a Tec Loc : 8 positions available) and
- a neck sheath.
I'm very happy with them. The finition is perfect.
The belt sheath is very convenient. You can adjust it as you want. The knife is well maintained (no risk to drop it).
It's much smaller that what I thought (from the pix I saw on this forum).
The neck sheath was first a gadget in my mind when I asked for it. But once I got it, I really appreciated it. It's not heavy (is a BM42 heavy ?). It's very simple (I like simple designs). You can even wear it under a tie (I'm gonna try this soon).
To my conception, it's a good thing that sheath can be done with a hair-dryer :-) (we say that, but it's not that easy, that's why I asked Clay to do the sheaths for me).
Second, this plastic is very robust/solid. It won't get worn like Cordura or Leather.
And it's quite futurist, I think it fits the BM42A perfectly.
Guillaume
www.balisong.net
Like said earlier, this is a great thread for those who have one of Clay's xsheathsx. I got mine about 2-3 weeks ago and was very impressed. The look of the thing with the knife in it has no comparison as far as looking like a bad ass is concerned. The fit is extremely tight and I don't think my 42 will ever fall out on its own.
As far as horizontal carry goes(I have a single belt sheath), I found that it is somewhat uncomfortable to wear this way. I have trouble manouvering the sheath into a comfortable position while driving because it digs quite well into my lower back. And taking it off and on every time I get in and out of the car is out of the question, so I wear it vertically with latch pointing up. The only problem with this is, if you don't yank the knife up quickly enough, you end up pulling your pants up with the knife, in effect giving yourself a kind of wedgeee!
Anyone know of a solution to this?
Also, Chuck mentioned that the Tek-Lok can be positioned over the center belt loop. I'm not sure how you accomplished this but I'd like to know how it is done. Maybe we have different clips.
All in all, I think the sheath is great and I use it every day. Anyone have any carry position suggestions?
if you're not now...you never were!
Hey, thanx for all the kind words.
I form the sheaths as tight as I can at the start. During the profiling and finishing stages I often hit them with heat to "relax" or adjust certain areas (the receiving holes for example).
After the eyelets are set, I do one final shot with the heat gun to relax the overall sheath a little, and slide a Balisong in and out a few times (while still warm) just to smooth the inside contours a bit. This leaves it tight, but with fewer "hang-up" spots. They will loosen up as the sheath gets aquainted to your Balisong (as Chuck mentioned).
I also tend to leave them a bit on the tight side for those that want to use them for the heavier BM Balis (44, 45)
BloodyKnuckles: Concealex usually requires you to experiment a little to find the correct Pull point. Sometimes grabbing from the sides and pulling, the knife will slide right out. Then again while grabbing from top/bottom, it might bind. There is always a sweet spot, it's just a matter of finding it.
On the horizontal sheath I find it smoothest to anchor my thumb just above the screw mounts and slide back with the rest of my hand to break the initial retention. It can actually be done very quickly with same practice.
As for the comfort of it, I understand exactly what you mean (which is why I wear the Inverted V). The forward mounting design leaves a lot of Balisong sticking out. Good because you can grab the Balisong and be right in position for the opening (no need to adjust hand position). On the other hand it does tend to stick out from your waist a bit much.
The sheath as I send it, is meant to be played with to get it just the way YOU want it. I've been carrying Balis long enough to know that people's carry prefrences are as diverse as their manipulation styles. No single design will work for everyone.
With that said, not only is that sheath multi-positionable, but if you notice the screw mounts I put TWO spacers on each post. If you pull one off of the back post, it will pull the latch IN closer to your body (when worn Horizontally on the side). You might find that more to your liking.
I encourage everyone to play around with their sheaths a little to find out what they're capable of. Who knows, you might come up with something the rest of us haven't thought of. Thats how these things progress.
Clay
www.balisongxtreme.com
Because......
getting 'em open
is half the fun!
This is true of sheaths and holsters in general. You need to spend time with 'em and get things adjusted just to your liking. I have found, for example, with Clay's belt sheath, that I've adjusted the angle and removed the extra washers so that it's now canted and closer to my body and I'm getting to like it even more.
Chuck
