Yellow line in micarta
I am finishing up my first knife and have noticed a yellow line running through one side of my micarta scales. Is this a defect, can I just keep sanding and it will go away? The other side does not have this and I think they are sanded down to the same level? Any info would be appreciated. Thanks.
What kind of micarta are you using?? Several of us had yellow/whitish spots show up in some black linen and paper micarta. I think it turned out to be a manufacturing error. You can sand thru it, just don't let it get hot. Post a pic of your knife when it's done. We'll blast ya good but in a kind way!
Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
My Web Site
Buzzards gotta eat, same as worms!!!
Ok here are a couple of pics, they are pretty bad.... As you can see the blade which was supposed to be flat is sort of convex, and the knife is pretty heavy, but I learned a lot on this one and will hopefully not make the same mistakes too many more times! I think you can see the yellow line in the 1st pic.
<IMG SRC="http://albums.photopoint.com/j/View?u=1406364&a=10512000&p=49098851&Sequence=0&res=high">
View
Oh, and it is black linen micarta.
[This message has been edited by ScottFM (edited 05-25-2001).]
Here is a pic of the sheath I made last night. It isnt perfect but came out better than I expected for the 1st try. The wife wasnt too happy about the smell from the kydex in the kithchen however....
<IMG SRC="http://albums.photopoint.com/j/View?u=1406364&a=10512000&p=49140519&Sequence=0&res=high">
Scott- heat is hard on micarta, whether paper, linen or canvas. Use clean, sharp belts. Sometimes there are manufacturing defects. And don't apologize for quality! I'm a newbie maker, everybody here was a newbie at one time. I like your design. Keep at it!
And if your wife doesn't like the smell of kydex- eat a can of beans and drink a 6-pack of cheap beer!!
[This message has been edited by richard rosvall (edited 05-25-2001).]
Thanks for the info, I will try to sand it down a bit and see if it goes away. Richard, I was at your web site a while back and really like those dragon pendants... I will have to get one soon. Thanks again
sharp belts and 80gr at slow speed. i just finished the handle on a bowie in brown canvas micarta. i get better grinding results with a 80grit than a 36grit. also use aluminum oxide belts not ceramic for micarta or wood. your knife looks a lot like my first, and there is nothing wrong with a convex edge. it's my preffed choice
Laurence Segal www.RHINOKNIVES.com
