- Mar 2, 1999
My Survival Minikit
I've made one I call
Bennett's Expedient Survival Tin.
This kit is designed to be a 72-hour kit. It is designed to be small and portable, but also to be effective in providing for the Survival "Rule of Threes."
The basic kit is enclosed in an Altoids tin, wrapped with 10 feet of 550 parachute cord. Note the 3/32" diameter hole drilled in the upper right hand corner of the tin. This kit provides for shelter preparation, fire making, water storage and treatment, signaling capability, basic medical needs and food procurement.
Contents:
1 Survival Cheat Sheet - the Universal Edibility Test, Body Signals and Ground-to-Air Signals
Shelter
1 large trash bag
1" piece of drinking straw, sealed and filled with 5.25% sodium hypochlorite bleach.
1 rubber glove (it's purple in photo)
1 BSA Hot Spark
10 matches with striker & cover
2 cotton balls
1 birthday candle
2 bandaids
1 small bolt w/ nut
1 safety pin
1 small SAK
2 jig saw blades
4 fish hooks
2 fishing flies - one wet, one dry
5 split-shot sinkers
15' 15 lb. test line
1 rubber band
Remember the 3/32" hole? The tin is modified to be a handle for the saw. The kit contains coarse and fine saw blades.
A slit is milled in the top lid of the tin and has a corresponding bottom of the tin has a channel cut from the wall of the side to allow the tin to close and to add support for the blade. A 3/32" hole drilled in the tin near the same location. A jigsaw blade, similar to that used in the Gerber multitool fits through the slit and the hole in the blade is lined up with the hole in the tin. A screw and nut turn the kit into a handle for the saw blade to make a mini-saw.
The 3/32 hole is also used as a sighting system for signaling. The inside of the tin is shiny. Use the hole to point toward the plane to flash signals to them.
Notes
Water purification - water is stored in the glove. To disinfect, use the bleach. The 1" tube provides about 8 drops of bleach. Puncture it and add 2 drops per quart to sanitize water as per FEMA instruction. Curious note: the Altoids tin filled 8 2/3 times (to the bottom of the hinges) makes about a quart of water.
Distance & Height Measurement - The cord can have a loop in one end and a knot at 36" from the loop. This 3 foot measurement works with the 3/32" hole to form a basic (READ: Good 'nuf) distance/height measurement system. at 100 yards, an image fitting in the hole is 9 foot 4 1/2" tall. 2/3 of the height of the hole - 1/16", is about 6 feet.
Thoughts?
Mike
Contents:
Shelter
1 large trash bag
1 BSA Hot Spark
2 cotton balls
1 birthday candle
2 bandaids
1 small bolt w/ nut
1 safety pin
1 small SAK
2 jig saw blades
4 fish hooks
1 rubber band
Notes
Thoughts?
Mike
