9blades;
Are you sure? I have seen lots of sparks when grinding 316 stainless against a grinding wheel. Looking at the "rock" used I thought that it looked like iron pyrites which is a very good spark producing mineral. It was used in the wheellock as the sparking material. The thing I found most questionable is that the brass bolster was what it looked like he hit the mineral with and brass is definitely not sparking normally.
First of all, my prior statement was a little broad, stainless will spark, but I've never heard of anyone doing it with flint. Also Keep in mind I only have a relatively crude understanding of the science behind this, I'm sure when your using a grinder a high speeds it will spark, my understanding is as follows: when you strike a piece of flint against a carbon steel or iron knife/striker the small bits of metal that are shaved of oxidize, and it's my understanding that a byproduct of oxidation is heat, in other words the sliver of metal shaved of oxidizes so fast it turns into a spark.
Now I said stainless wouldn't spark, which isn't true (to an extent it was true in the contexts it was used) I was (and still am) under the impression that it was harder to make stainless spark because it doesn't oxidize as quickly...I could be wrong, that's just my understating(please remember it is 1:00, its possible None of what I said makes sense)
Lastly, I thought the only purpose of the rock was to shave metal off the steel in question (again could be wrong)
Here's some good reading on the subject.
http://survivaltopics.com/article/flint-and-steel-what-causes-the-sparks/
They might show it right before the next episode. I think it comes on MondaysDarn it; I missed that episode. Just set up for series recording. Perhaps that one that I missed will be run again. Decent program last year.
sonnydaze
