- Aug 26, 2010
I was playing around with the pile of burned steel again and made what Im calling the Zak-e-toh because it looks like a big exacto knife
It has been on the table by my side and has become a much more useful tool than I ever imagined so i wanted to tell someone about it. It is well suited for trimming flesh and picking thorns, splinters and other minor surgical procedures which is almost a daily occurrence for me and my self inflicted wounds. This is my second ever attempt at differential tempering. No its not a Khukuri but Its a doggone useful tool
It has been finished on a japanese waterstone to 8000 grit and is convex ground. It is shaving sharp! It also has a point much like a new exacto blade but a bit thicker for durability reasons.
The blade was quenched then tempered with a propane torch at the spine to spring temper (purple) leaving the edge at straw color for proper edge hardness. This is not easy to do! Hats off to anyone who has mastered this!
The tip was very springy and returned back to position like its supposed to so it must have worked.
This was the plan: Curl the handle to wrap around the finger so it wouldnt slip or twist around during "surgery".
Then cut some finger knurls for a bit more control. I know they make a special file for this and have seen them do it making straight razors but i thought id try it with a triangle file. Looked great for a near blind man till I zoomed the pics? Oh well it works! I clamped a hacksaw blade along the spine to use for a guide then once I got started I could unclamp it and file deeper. Sort of worked.
I saw a primitive sheath one time that used staples in a wooden sheath that left the blade exposed and thought that was really cool so this is my modern rendition to that idea using magnet wire and an oak root burl I found buried in the yard. This is what I ended up with. I figured I could bend the wires inward to retain the blade if it was loose and it did work well.
I started out with pulling a loop in the wire and winding a coil from there. I cut grooves in the back to bury the wire in and continued wrapping until I got to the end.
Once I got to the end I stripped and tinned the wire and bent it over and melted a solder ball in the hole to retain it. File it off and done deal.
I did rub the wood down before assembly with boiled linseed oil. I really want to try this with a larger sheath and knife. This was just practice run so I dont screw up something bigger. It was fun and learned a few things so hope someone likes it! Enjoy!
