Not really. Laminate is softer/weaker steel as usual, so it can weaken overall strength of the blade.laminate is almost always better than homogeneous steel, thats the reason they do it.
I'm not Sal, but I thought the solid vs. laminate issue was due to the ability of whichever factory each knife was built in being able to grind or laser cut ZDP, at least in Spyderco's case. The Endura and Delica are less expensive than the Caly 3, you would think if it was a cost issue the laminated blades would have been used in the Endura and Delica models. In use I find no difference except the laminated blades scratch easier, but both cut equally well. I have used laminated Caly Jr & Jess Horn ZDP's, and my solid Endura ZDP.
Mike
Well, that IS what Sal told us when we asked why some were laminated and some were solid.
The biggest difference I have seen is the laminated blades are ground thinner from the factory, but Tom Krein can fix that.![]()
