- Dec 31, 2010
Would the norton india oil stone be able to handle a steel such as ZDP-189?
I'd be inclined toward diamond too, with ZDP. And a bench-sized diamond hone is more ideal for it, for shaping the edge. Very small diamond hones can even be slow with ZDP; I found that out the hard way, in trying to rebevel a ZDP-189 blade (Kershaw Leek) with a Lansky diamond set. It was very slow; I regrouped and switched over to an 8" Duo-Sharp bench hone instead, and working speed was cut about 4X.
I've used a zirconia-alumina 3" x 21" belt, cut and affixed flat to a hard surface, to reshape a broken tip on the same knife (again be cautioned, beware it's brittleness), and that worked very well and fast, taking only ~20 minutes or so. The belt's length made long, sweeping strokes easy on the abrasive, which I'm sure was a big factor in working speed. Zirconia-alumina is a somewhat toughened version of aluminum oxide, touted to work longer before the grit loses it's cutting power. That project was a bit of an eye-opener for me, which is why I think aluminum oxide can sometimes work OK with ZDP, depending on the specific job at hand.
David
David and Russ, other than a longer abrasive surface, any other advantage of a belt over a coarse waterstone?
Luong (bluntcut) turned me on to this method with a blaze 200 grit belt affixed to a granite rectangle. The belts are 4" by 32" I think and I cut them in half. I thinned a huge ontario bowie with it and the sweeping surface are was awesome for the job. I also used it on a zdp stretch and it worked quickly. Another good call David...
Russ
When using the belt on granite, do you use edge trailing strokes, or is the belt tough enough to do edge leading with scrubbing motion like on a stone?
